(Car is technically a sport coupe - RS - despite the badging)
$15,500
I’ve been building this car for the last 7 years and have run out of time/desire to finish it. The engine bay and bottom of the car were stripped bare and painted. It’s spotlessly clean, has no rust, and needs little to be a ton of fun. My original intent was to do HPDE track days with it. 90% of the parts on this car are either brand new or just rebuilt. Car will come with whatever spare parts I have (or new parts I have not installed yet).
Summary: Paint: 9/10 Interior: 10/10
Motor: 1995 LT1, less than 100 miles since rebuild. Factory computer with brand new wiring harness. CC503 cam, ported heads/intake. ARP fasteners throughout. Shorty headers to 3” exhaust that’s been wrapped. Approx 350hp. PCV catch can installed. Canton road race pan.
Transmission: 1995 T56, less than 100 miles since rebuild.
Cooling: Be-Cool aluminum radiator Power steering cooler Motor oil cooler (not installed) Dual electric fans
Suspension: Eibach 1.5” drop springs KYB Gas-Adjust Shocks Z28 sway bars Wonderbar Full poly-bushings throughout All new steering links & ball joints Perimeter & tunnel sub-frame connectors Adjustable panhard bar Lakewood lower control arms Adjustable tubular torque arm Strut tower brace Adjustable caster/camber plates
Brakes: Wilwood 4 piston rear discs LS1 front brake conversion All new stainless lines
Tires: New BF Goodrich Summer Tires
Interior: New gauges (oil temp, oil pressure, diff temp, trans temp, O2, coolant temp, fuel pressure) New Corbeau race seats New headliner New carpet New visors
Needs: Water pump (brand new one leaks...thank you NAPA) Speedometer hookup (Dakota Digital box will come with car, just install) High torque starter (again, NAPA starter is too weak when hot)
No trades, no scammers, no offers to help me sell the car. Cash only.
To clarify: the car is perfectly driveable. The starter is an issue when the car is hot (as stated above) and the water pump is only weeping from the drip-hole.
