[NJ] 1991 Z28 Vert Supercharged 6 speed $19,750
Car: 1991 z28 convertable
Engine: TPI 383 Procharger P1SC
Transmission: 6 speed
Axle/Gears: 373
1991 Z 28 Camaro
to preview picture: http://flic.kr/p/cdG9Vh
Call 609-529-7900 for info and I can send more pictures or e mail greatrazoo@aol.com
This 1991 Z-28 Camaro has 75,175 miles and has only 10,000 miles put on it in the last twelve years. Garage kept and well taken care of all of the modifications were done over an 8 year period. It took first place at the GM Nationals in Carlisle PA. for modified 3RD Generation two years ago and was in Super Chevy and Camaro magazine.
A basic description of this car will be followed by a detailed list of parts. It’s a 1991
Z-28 factory Convertible which came originally with a 305 Cubic inch V-8 and a automatic transmission.
It currently has a 350 Cubic inch Block with an Eagle Crank, it’s now a 383 TPI with a P1SC Pro charger and intercooler. I put a brand new in the crate Tremec 6 speed with a Hurst short throw shifter. I replaced the flywheel with an Spec aluminum flywheel, pressure plate and clutch. The slave cylinder is new GM with a stainless steel line from the reservoir. GM three rivers aluminum driveshaft. GM disc brake rear with 323 Posi differential. Fully adjustable rear shocks, with welded in Kenny Brown frame connectors.
SLP adjustable torque arm. Eibach 1.5 inch lowering springs all the suspension parts are new, ball joints, tie rod ends bushings. The brake calipers rotors and pads are new. All braided stainless brake lines. Chrome strut tower connector and much, much more.
Engine
- 383 Cubic inch Chevy
- P1SC Procharger with intercooler
- All piping is powder coated for Procharger
- Mini starter
- K&N air filter
- “Be Cool” aluminum radiator
- Twin Spal electric shallow fans
- BBK Plus throttle body
- VMS oil catch can
- All relays and sending units are new
- Dynamic EFI EBL lockers flash system w/ port Mod
- Chrome Siamese intake runners
- Alumi coat headers
Transmission
- Tremec T-56 BRAND NEW!
- Spec Flywheel ,Clutch and pressure plate
- Hurst short throw shifter
- Posi traction disc brake rear 3:23 ratio
- SLP Torsion bar
Exterior and underneath
- Flaming river power cut off switch
- Remote located Optima dry cell battery in trunk
- Aluminum GM driveshaft “Three Rivers”
- 8 position adjustable rear shocks
- Eibach 1.5 lowered springs
- Kenny Brown Frame connectors
- SLP torsion arm
- Brand new gas tank and in tank fuel pump
- External electric fuel pump
- Boss Motorsports wheels
- Riken Raptor tires 275-35 ZR18 rear, 245-40 ZR18 fronts
- Brand New Cat Converter and O2 Sensors
- GMMG stainless chambered exhaust with stainless tips
- All Lights, Lens, and emblems are GM OEM
- New GM slave cylinder with Braided stainless line
- New windshield
- OEM driving lights new
- White gauge face
- AEM air/fuel gauge
- AEM boost gauge
- Fuel pressure gauge
- Grant steering wheel
- Chrome fire extinguisher
Last edited by 1991z28ragtop; 06-11-2012 at 07:04 PM. Reason: can't insert pictures
Car: 1985 Iroc Camaro, 1974 type LT Z28
Engine: modified L98 corvette, L82
Transmission: 700r4, Turbo 400
Axle/Gears: 3.42, 3.42 posi
Re: 1991 Z28 Vert Supercharged 6 speed $19,750
pictures?
Axle/Gears: 373
I couldn't download picture although a link was put in to see the car. You can e mail me at greatrazoo@ aol.com or go on E bay motors I posted 24 there although I have many more. thanks
bjpotter
01-22-2019 12:27 PM
CarGuyDennis
137
12-06-2016 11:02 PM
toronto formula
11-10-2015 06:17 AM
1991, 1991z28, 1992, 383, camaro, charge, convertible, gen, procharger, sale, speed, supercharged, surper, z28
