91 z28 convertible 90k car !!!SOLD!!!
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 89 formula convert looks like a 92
Engine: original 350 tpi engine
Transmission: auto
Axle/Gears: 373 10 bolt with LS1 brakes
i have a red 91 z28 convertible with a mint black interior even has a mint dash pad, custom front floor mats, tan top 305 tpi with 90365 miles on it, its an auto, car has mant new parts, both fog light work and i had custom black out covers over them to protect the lenses, dont want to sell but house needs work, and the work has to get done,
list of new gm parts,
outer window felts, rear shocks, brake drums, shoes and hardware, rear wheel cyclinders, front sway bar end links, front struts, front caliper and hoses, brake pads, fuel pump, pressure valve in line to the sending unit, sending unit, fuel filter, injectors, cap , rotor, wires, plugs, coolant temp sensor [ for the fans] and new connector, both front marker lenses, lower front spoiler and had it painted, also have new tuneportinjection badge and z28 embelm for the back bumper, there is a good bet theres more i just cant remember all of it
non gm parts,
kumho tires 245/50r16 , inner- outer centerlink idler arm and lower balljoints all moog parts, oil pressure swith and vehile speed sensor [standard parts], 2 k&n filters, dynomax cat back with polished muffler, spohn tie rod sleaves, gates serp belt, wiper blades ect...
just got the car home from haveing the alighnment done,
the bad,
minor dings in it small scrap in the passander fender, its the original paint and the clear has started to crack and come off the hood blisters and convert top caps, i replace the tonneau cover [ fabric torn ] and had it painted red just so it matched not perfect but plans were to have the car repained and make it look perfect, windshield has a scrape in it, [ from wiper blade]
have plenty of pics just ask,
asking $4500 or best offer, house is a saftey hazard and with 4 kids it must be fixed,
non gm parts,
the bad,
Transmission: auto
Re: 91 z28 convertible 90k car
sold ,, cheep had to go...
1992 Trans Am
05-10-2023 07:19 PM
IROCZDAVE (88-L98)
10-06-2016 09:08 AM
IROCZDAVE (88-L98)
08-06-2015 03:51 PM
