Corvette calipers, LS1 Camaros rotors/ pads compatibility
annoying clunk (sounds like metal to metal) when driving over potholes, speed bumps and the like. Car (91 Trans Am WS6) has pretty much all new front end suspension and steering parts and all seems to be torqued correctly. Cannot replicate in driveway by bouncing the front end nor really with the front jacked up (and supported) and knocking the front tyres with a BFH at different positions. But very apparent even with slight bumps in the road.
I have installed 'LS1' front brakes comprising camaro discs, corvette C5 callipers and camaro pads. Have the anti-rattle clips installed and callipers seem solid as do the pads.
Still, might this combination be the source of clunks? Reading around on LS1tech and the the like, seems C5 callipers are a 'done' upgrade for LS1 Camaro/ TA people and they keep Camaro pads and rotors and don't see reports of issues thereafter
Really confused with this one!
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Re: Corvette calipers, LS1 Camaros rotors/ pads compatibility
You sure it's not something like in the engine shifting? Maybe a bad motor mount etc....
I havea car that also only makes noises over bumps etc... from what I can tell its bad lower control arm bushings.
Engine: 4++,350 & 305 CIs
Were the swaybar endlinks replaced?
Thanks both
the noise did take me to suspension and mounts. All bushes, end links, top mounts, steering joints, are all new and I’ve double checked torque. Also cannot see any clear witness marks as a guide to what’s causing it
springs are indexed correctly. Struts are not new but can’t see them causing it and again no noises when I compress the suspension in the driveway
Engine does not seem to move much on revving / rocking it
exhausting the suspension side of things, I’ve picked up on other threads where braking components were causing rattles
Engine: 3.4 / 5.0
Maybe its the type of pad you used.? I had some junk pads that made some weird noises. Swapped them out... noise is gone!
Car: check
Engine: check
Transmission: check
Bend the anti-rattle clips to put more pressure on the pads/caliper. BTDT, drove me daffy until I did that.
The issue is that the pads are rattling in the abutments. Need more tension on the anti-rattle _!@#$&*(/_ springs.
RBob.
RBob.
I had the same issue as you but with the stock calipers. Driving on the street I would get that clunk when I would step on the brakes. At first, I thought it was a ball joint so I took it to a mechanic to get a second opinion and he said nothing was wrong. The noise was only coming from the front driver side. When I swapped out the wheels I to a look at the pads and it seems like it had some low quality pads that were moving a bit while the caliper was still bolted on, similar to what Rbob mentioned above. I swapped out the pads with an extra pair I had and these had no play. Took the car out for a drive and noise went away. 2-3 weeks later the noise came back but its not as often. I looked on TGO and some members complained about the stock brake pads making that clunking noise.
Thanks team
have ebc green stuff pads and discs. It’s possible there may be a manufacturing defect with them, but otherwise I understand these to be a decent enough brand and street pads
Yeah I should have time with the car this Sunday and have new guide pins, seals, grease, and rattle clips (for c5 callipers).
will report back
will report back
so just finished fettling and most of the noise seems gone.
rattle clips seemed loose and the bolts for the Caliper guide pins seemed to have loosened up. The passenger engine mount bolt also was finger tight
So after replacing stuff and torquing down correctly and a quick round the block, I think I’m good
have a longer trip planned next weekend so will firm up then, but so far, pretty relieved!
The following 2 users liked this post by GTA1990:
DynoDave43 (11-09-2023), TTOP350 (11-05-2023)
Engine: 3.4 / 5.0
if all those things are loose you may want to do an overall checkup of everything to make sure major parts / components are tight.
Was there major work done recently? I canlt imagine why caliper bolts and an engine mount bolt would loosen up like that by itself.
