Wilwood 6 piston Upgrade
If you have cut your spindles for the wilwood front brakes. (4 Piston) Kit. and would like to upgrade. Wilwood makes 6 piston calipers that are a bolt in upgrade. They are big and look Good as well. (NOTE: the bracket for this set up)
If you have the 4 piston kit..this is the 6 Piston Calipers...Bolt in place of the 4 piston..
zoidberg355 (11-23-2021)
