10 bolt flange question
Car: 1983 Camaro Z28
Engine: 350 Carb
Axle/Gears: 323 Posi
So I pulled apart my 10 bolt drum brakes, all the way down to the flange and I am wondering if there are any options for converting this rear end to discs, or should I just hunt for something else, either from the junkyard or aftermarket.
Engine: 350 Carb
Re: 10 bolt flange question
Might have found the answer:
Nope. Never been done before.
http://flynbye.com/catalog/i30.html
http://andyz28.com/3rdGen/reardisc.html
For info concerning the master cylinder and combination valve and so on, check the following FAQ:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
JamesC
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
You don't need fact brackets to convert it.
The 98-02 ls1 year brakes fit right on. Drill out the 2 small holes to match the backing plate, cut the top part off and drill the other two holes. Then bolt them on.
Engine: 350 Carb
Thanks. Found the YouTube video above where someone does just that, so that's the plan, except I might just go with Wilwoods.
