Brake lite
Car: 91 RS convertible
Engine: 330 hp vortec 350. TBI
Transmission: 5 Speed
Axle/Gears: 3.73 Moiser 12 bolt/Wilwood disc's
Brake lite
I have a Willwood adj. prop valve. When I hook up the brake light switch it does just that lights the brake light.
How do I make it work right? Shoot what is right? What does it meen when the brake light is on and the parking brake isn't.
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: Brake lite
It means the internal switch is tripped. Hook the brake up and press the pedal really hard, light should go off.
Re: Brake lite
Still no ideas how to fix it. I don't have any issues except the lite.
I fixed everything else. It used to come on only when I braked. There was a problem with axle movement. I fix that now the lite is on all the time.
Re: Brake lite
I found out why it is on all the time. The 2 lugs were touching but now the brake lite comes on only when the peddle is applyed.
So it comes in because of a differential in pressure between the front to back?
Re: Brake lite
Really Bob? I feel real stupid but the instructions are poor. So there is no break light switch. Was wondering why there are 2 spades off the back of the switch. I hooked up the wire and grounded the other.
Car: check
Engine: check
Transmission: check
Re: Brake lite
Next time the brakes need to be bled I'd remove the switch and replace it with a pipe plug. It is a 1/8" - 27 NPT thread.
RBob.
dbrochard
09-19-2015 08:13 PM
