bleeder rod on combination valve
I'm bleeding the lines and read in the service manual that I need to depress the bleeder rod to allow flow to the front brakes. I have tried to depress the valve but it won't budge. I saw this image on another site and noticed how much the bleeder rod sticks out and wondered if the rod on the valve on the car is already depressed. Can you tell from the pictures? If it is already depressed, why might that be? Thanks.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: bleeder rod on combination valve
Never had to push anything to bleed my brakes
Received 1,720 Likes
Never even heard of "bleeder rod".
Of course I've only been doing this since the 60s, so I'm really just a n00b; lots left to learn about, I'm sure.
Once I get the master cyl properly bench bled and all the air out of that (since at the angle it sits at in these cars, there's several cc of cyl that's ABOVE the lines, and that's where the air goes, and NO AMOUNT OF BLEEDING EVER will EVER get air out of up there) then I usually just crack the RR bleeder screw, pop a cold one, and sit and watch until clean fluid comes out, making sure of course to regularly top off the MC so I don't have to start over; then close it up and do the same to the LR, which is MUCH quicker at that point since the line that runs the length of the car is already bled; then about that time, another cold one is required, and I repeat the process at the RF, which takes a bit of time, maybe half as long as the RR; then the LF which is SUPER quick. Pretty mcuh devoid of any hint of any actual "effort" let alone w... wo.... (OK mods, don't ban me for using 4-letter words that end with a "k") work, except for the bench bleeding part, which dimly resembles ... that ..... nasty 4-letter stuff, but only a little bit and only in a qualitative sort of way.
If so, then with a larger pressure spring like in the 1LE valves (The later year combo vlaves- you have an early one) the spring pressure is a little more than the non-1LE valves so as to allow for movre pressure to run to the rear brakes. This would call for either slightly loosening the bleeder nut in a gravity bleed, or you will have to manually bleed them by pumping the pedal and forcing fluid to open the spring load and put presurised fluid into the front system. Look at the graph and you can see how as fluid comes into the center chamber it goes through and presses against the spring to open more to get more pressure to the fronts. The higher this spring prssure is, the more rear brake pressure.
Jerry (JerryWho) machined a neat little threaded punger type divice for his car that allowed for a bias adjustment in place of that bleeder rod cap. This put different pressure agaisnt the back side of the spring based on screwed in length. and a jam nut on the outside to prevent unwanted turning like a rodend jam nut does. Preety nifty little device Jerry made.
What that diagram has labeled as a "bleeder rod" does not move or have any button to press. It is kindof built like a nrake caliper bleeder nut. You can also put washers between it and the spring to increase rear brake pressure.
Does the manual you are reading talk about "gravity bleeding"?
So, why is it depressed? Found the following on an El Camino forum: "The old valve is "tripped" thinking the rear brakes had a failure, thus shutting off flow to them. Now you have to trick it, with master full, and lid on, have someone loosen both front bleeders, and push the brake pedal as hard and quick
![](http://images.intellitxt.com/ast/adTypes/icon1.png)
Hotrodboba400
12-10-2019 07:07 PM
