No brakes at all. No fluid when trying to bleed. And Pedel is to hard to push down
Car: 1984 Chevy Camaro
Axle/Gears: 7.5in 10 bolt with 3.08
84 camaro. I couldn't get the old calipers to bleed so I figured it was them. I replaced them and now the new ones will not bleed either. I replaced the master cylinder and still nothing. No fluid comes out of bleeder. I even disconnected the line from the caliper and still no fluid.
My brake Pedel is also too hard to even press. You can't even push it down an inch when the car is off. With the car on and idling it moves a little but it still is too hard and still no fluid coming from lines.
Any advice is appreciated. Thanks!
1 Post
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Re: No brakes at all. No fluid when trying to bleed. And Pedel is to hard to push dow
clogged prop valve?
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
https://www.thirdgen.org/forums/tech...edro-like.html
You guys may want to collaborate.
Car: 85 Z28
Engine: 327
I have had a simular ( kindof) problem where brake caliper wouldn't decompress. Just locks on rotor. I can manually decompress it, but when I bleed nothing but air comes out. All other brakes work good. I was also told was rubber hose. But changed it and same probwlem. Therefor it has been just sitting since last june
Car: 1990 T/A w/WS6
Engine: 5.7L V8 TPI
Axle/Gears: 3.23 w/ posi
I had a simalier problem, though certainly not as extreme, it was caused (it seems) by kinked metal lines, i would recommend changing a couple to see if that changes anything.
