9-bolt disc ?
Car: 1986 Monte SS 383, 70 SS396 conv.
Engine: 396
Transmission: th400
Axle/Gears: 3:42
9-bolt disc ?
Hi, Ok I am going to install LT1 rear disc on a 9-bolt. I ordered the brackets, the question I have is. Do I need to remove the axle bearings to install the caliper bracket or does it go under the retainer for the axle bearing? Thanks for any Help,Ray
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Re: 9-bolt disc ?
Not sure i completely understand the way you worded your question but ill answer what i know. To swap the caliper mounting bracket you must pull the axles. The bearings are pressed onto the axles and while you have it out it might be a good time to redo the axle bearings and seals. If they arnt leaking however than maybe just throw them back in and run them. You will need a slide hammer to get the axle out. Once you do that you can pull the backing plates off and replace.
Engine: 396
Transmission: th400
Axle/Gears: 3:42
Re: 9-bolt disc ?
Hi, I am not sure which side the caliper mounting bracket goes on, the side toward the axle flange or towards the diff. housing? Ray
Re: 9-bolt disc ?
https://www.thirdgen.org/forums/atta...89-bplate2.jpg
10-bolt:
https://www.thirdgen.org/forums/atta...s-89-shims.jpg
JamesC
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: 9-bolt disc ?
Not sure if the "10-bolt" it is referring to is a 3rd gen one or not, but if the 3rd gen 10-bolt pattern & 4th gen 10-bolt pattern is the same.....The LT backing plate should be able to be modded to fit pretty easily.
KO1
16
10-15-2015 05:00 PM
