89 9 bolt pbr
1 Post
Car: 1988 Gta trans am project 1-1/2
Engine: 86 4 bolt main cammed sbc 355 hsr
Transmission: 89 wc bw t5
Axle/Gears: Bw 9 bolt (3.27) pbr 11in
89 9 bolt pbr
Ok so I got a 88 Gta with the non performance brake package I have a 89 Gta 9 bolt with the pbr brakes I was looking into swapping it all out put the 89 rear in my 88 do I have to change anything over to make the 89 pbr work
Re: 89 9 bolt pbr
The 9- and 10-bolt braking systems are identical (with the exception of the backing plates), so the following link will provide pics and part numbers:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
1 Post
Re: 89 9 bolt pbr
Ok so I got the 88 9 bolt out today an cleaned up the 89 pbr rear end. I'll paint it tomorrow an get ready on the install of it so what proportional valve do I need exactly. should I just get one from autozone with the performance package with disc brakes??? also I checked there today to get new e brake cables an they are not available there, what auto parts stores will carry them for a 89 gta rear end with the performance package ???
Re: 89 9 bolt pbr
Check the link in post #2 for various parking brake cable part numbers.
JamesC
1 Post
Re: 89 9 bolt pbr
Ok so I gotta get the first design master clyinder for drum brakes anything 84-92 for the proportional valve I'm just gonna ask for one at autozone with the proformance package with disc brakes
Re: 89 9 bolt pbr
https://www.thirdgen.org/forums/susp...fferences.html
The disc combination valve, 82-88, is designed for cars equipped with the Delco-Moraine system (10.5" rotors and iron calipers), the 89-92 for cars with PBR's (11.7" rotors and alum calipers). Of the latter, there are two designs, one for mid-89 down with M1.0 tube nut threads and one for mid-89 up with M1.5 tube nut threads. That you'd be able to purchase the valves at an auto parts store is unlikely.
JamesC
1 Post
Re: 89 9 bolt pbr
Ok so I found this master cylinder http://www.autozone.com/autozone/par...7_56045_0_7735, is this the right drum master clyinder I will need to make this work for the proportional valve looks like I'll just order that one from flyinbyperfomance.
1 Post
Re: 89 9 bolt pbr
Ok sounds good I'll bring my lines to see if they thread in no prob am then I just gotta find a proportional valve for the 1le
Car: 86 Z/28 IROC-Z
Axle/Gears: 9 Bolt 3.27
Re: 89 9 bolt pbr
If you have standard 4 wheel disc, 10" ones front and rear. You can install the pbr's out back "without changing anything else". You will love the braking balance.
Now if you put the pbr's out front, then you need to change master/prop.
Re: 89 9 bolt pbr
The proportioning section of the combination valve is usually used in the rear brake line.
JamesC
1 Post
Re: 89 9 bolt pbr
Then why is everyone telling me that I have to change the prop valve, an master if I keep the set up I have now will it give me a soft long travel pedal ???
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
Re: 89 9 bolt pbr
My car is a swaped from 87 2.73 drum posi to 3.27 disk posi brakes fine but I will change when I do the ls1 brake swap, I gave the calipers painted just need to mod the other stuff
Re: 89 9 bolt pbr
Personally, I'd prefer using the combination valve designed for a specific braking system: There are different valves for disc/drum, for disc/disc, and for disc/1LE. Each apparently with a different bias.
JamesC
JamesC
Re: 89 9 bolt pbr
89-91 shows the same Cylinder, Brk Master GM 18014286. Earlier years show different masters for J50 and J65. GM, however, pretty much made them interchangeable:
There are different combination valves (if only one was needed, why would GM design valves for different applications?). For exampe:
Valve, Brk Combo (1989 2nd Des) (J50) (1990 [and also 91]) (J41, J42) GM 10136839
J41 - BRAKE SYSTEM, POWER, FRONT DISK, REAR DRUM, CAST IRON
J42 - BRAKE SYSTEM, POWER, FRONT DISK, REAR DRUM, ALUMINUM
Valve, Brk Combo (1989 1st Des) (J65, 1LE, Y82) GM 14089496
J65- BRAKE SYSTEM, POWER, FRONT & REAR DISK
1LE - PERFORMANCE PACKAGE, SHOWROOM STOCK RACING
Y82 - MERCHANDISED PACKAGE, FORMULA
JamesC
1 Post
Re: 89 9 bolt pbr
Ok so what I'm gonna do is try it with the master an prop valve I have now an see how the pedal will be if it isn't to my liking then I'll just order all the stuff for the 89 set up I'm trying to redo this car on a budget
Re: 89 9 bolt pbr
The disc/drum and disc/disc valve will stop the car (but I'm uncertain of how well or efficiently). To be truly assured of the best performance from 1LE brakes, the best choice would be 1LE components designed for that system.
You might also peruse the following link, which details both the front and rear 1LE swap with pics and part numbers:
http://web.archive.org/web/200605221...e.html#1LErear
Best of luck on your project.
JamesC
JamesC
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: 89 9 bolt pbr
do believe the problem comes as the prop valve for rear drums is designed to keep or hold several PSI [ I think its 7-9] of pressure in the rear lines so the drums work proper, been that way on GMs for a long time. As drums take longer to react if not. One might notice a bit of drag in the rear with rear disc and/or shorter pad life with a disc/drum prop.
cheapest solution is hit ebay for a "hotrod" brass prop valve of your liking, [disc/disc, disc/drum] it will use standard thread fittings and is easy to cut off the metric end and reflare them.
Its what I did and now the only places I have metric ends is where it screws into the MC and in the rear. but plan to change the rear parts for standard ends next time around.
[hate those double flare import metric line, I have a GM not a toyota]
Car: 86 Z/28 IROC-Z
Re: 89 9 bolt pbr
They also wouldnt tell you you need the 1le prop valve for sure, thats for full 1le brake system front and rear.
We did this pbr swap on my car, and my brothers. All we changed was the rear end/brakes. < and the brakes worked awesome!
Once the vette brakes went out front, do you/we needed to changes other stuff.
Re: 89 9 bolt pbr
http://www.flynbye.com/catalog/i40.html
There are only two 1LE valves. Except for the difference in tube nut threads they're the same.
JamesC
UltRoadWarrior9
09-02-2015 08:24 PM
