aussie 9 bolt with DRUM prop valve??????
Car: 91 Camaro RS
Engine: 350 +60 Air gap Custom 750 DP
Transmission: 700r4 Stage 2 2400 stahl
Axle/Gears: Aussie 9 3.27 Posi
whats up guys? here we go. 91 camaro, stock 10 bolt DRUM rear, i just bought a aussie 9 BOLT with DISK brakes. can i run a STOCK DRUM prop valve for the weekend (woodward dream cruise in MICHIGAN)????????????????????? has anyone ran the DRUM prop valve with DISK rears?????????????/
Thanks guys!
Adam
Thanks guys!
Adam
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: aussie 9 bolt with DRUM prop valve??????
sure, it will work, and if the 9 bolt has the iron calipers, they generally dont work anyway so the prop valve wont matter
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
I run a drum prop valve ever since dropping in my 9 bolt with the bigger brakes (12" I think). Seems to work fine.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
JamesC
