Brakes are.locked up in the front
Car: 83 CaMarO Z28
Engine: 383 stroker AFR heads 600hp
Transmission: 700r4 stage 3
Axle/Gears: 373 9"
My brakes locked up only.in the front, wht the h e double hockey stick do.i do??
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Re: Brakes are.locked up in the front
You probably have a froze caliper? Take them apart and find out. Where are you at in Ohio? I am in Columbus, have calipers if you need....
All it takes is one frozen caliper and the car won't move, some more details would help. Have you jacked the car up? Are both wheels froze? ?????
Car: 85 Z28 T-Top 36mm sway & wonderbar
Engine: TPI L98 350 W/85 Vette Stage II ECM
Transmission: W/C T-5, alum drive shaft
Axle/Gears: 9 bolt posi, 3:27, PBR's, BB LS1's
I have a master cyl, rotors and calipers and new pads that I recently taken off my 85 Z28. I upgraded to LS1 front brakes. All was working fine, the flex lines are showing their age though.
PM me if interested.
Car: 83 CaMarO Z28
Axle/Gears: 373 9"
Well I replaced the front cals n pads..they still wanted to grab now the rear driver side drum is grabbing?
Hoses are collapsieng on the inside....
Could it be a proprtioning valve? This happened to my car rears would lock uop before the fronts, then right front would lock up till it bled down. Just saying what happened.
Terrell351
06-13-2021 01:13 PM
