Goodridge G-Stop 5 line hose kit opinions.
1 Post
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
I'm looking for braided hoses for cracked hose replacement and upgrade. I've seen threads knocking Earls and Russel. Has anyone used the Goodridge G-Stop 5 line kit? I've got a '91 v6 and I'll be adding rear discs. Are they good and is it possible to buy just the front hoses because I don't know when I'll get to the rear swap? Best place to buy?
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: Goodridge G-Stop 5 line hose kit opinions.
havent used them personally, but i was looking at some of their hoses at their booth at SEMA last year and they look pretty solid. they are DOT approved, so thats a good sign. But earls and russles are too....
Car: 87' IROC
Goodridge makes excellent products. They would be my first choice for any vehicle. I bought a 5pc kit just for the rear section. I'll grab some pictures of the unused fronts. Base91, if you can't find a front only kit, let me know, I'll help you out.
1 Post
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
I'll keep it in mind. Thanks. I found the kit on tirerack for $141.
you should be able to get them with a black pvc coating too. added corrosion resistance and a more stealthy look
1 Post
Car: 1984 Berlinetta
Engine: 305 Carb
I have them on the front of my 84 and was really impressed with the quality and the fit.
ambainb
04-25-2016 09:21 PM
gixxer92
09-01-2015 04:32 PM
