master cylinder leak air bubbles
Car: 1988 gta notchback
Engine: L98 5.7 TPI
Transmission: 700 R4
Axle/Gears: 3.27 POSI
hi i have a 1988 gta 5.7 4 wheel disk brakes the master cylinder went bad so i replaced it and i bench bled the master cylinder and installed it and then bled the rest of the brake system however when i step on the brake pedal i get air bubbles in the back half of the master cylinder res and i have brake fluid leaking between the master cylinder and res both parts are new so just to make sure the parts were not the problem i returned the master cylinder and res and bought a new one installed parts and i have the same problem this is my daily driver so i need to fix asap please help
