Different pressure at the calipers
Car: 89 Iroc-z
Engine: 5.7 lt
Axle/Gears: 9 bolt
i have a 89 iroc and i have been having the problem that when braking the car would pull to the right. so i thought bad driver caliper right? so i changed both front calipers and pads. i bleeded the lines on both sides and when i bled the drivers only a trickle of fulid came out while the passanger came shooting out. what might be the problem
Car: check
Engine: check
Transmission: check
Re: Different pressure at the calipers
RBob.
Car: 89 Iroc-z
Engine: 5.7 lt
Axle/Gears: 9 bolt
that would be that rubber tubing that goes from the hard line to the caliper?
rb85TA
26
09-14-2015 10:29 PM
rudolphschenker
09-04-2015 02:41 AM
