Rear disc when putting an 88 9 bolton an 89
Car: 1989 Pontiac Formula 350
Engine: 350 tpi
Transmission: 700
My car is an 89 and has the factory pbr rear disc and a 9 bolt. Well the 9 bolt died and I found a good 9 bolt out of an 88. It has disc but of course the old style. How hard will it be to switch the old calipers out with the pbr setup?
Re: Rear disc when putting an 88 9 bolton an 89
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
Received 1,839 Likes
Worst thing is, you gotta pull the axles to swap the backing plates. Other than that a piece of cake. And that's not even THAT bad. So you'll be OK.
Engine: 350 tpi
Transmission: 700
So it will be a direct bolt up swap?
hectre13
12-11-2023 08:14 AM
sailtexas186548
01-19-2016 12:21 PM
novaderrik
08-10-2015 12:44 PM
