Brake Pedal goes to floor sometimes?
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I finished installing a C5 front and an LS1 rear brake kit on my car, and now I am sometimes having the problem where I will be slowing down and the brake pedal will go almost all the way to the floor. It doesn't want to stop so I will have to let off and try braking again. However after it does this, it may not even do it again for a few days. What could be causing this?
Car: 88Fbird,88Formula,04 GP,04 Durango
Engine: LO3,L98,3800,HEMI
Transmission: 700r4, 4l60e, 545rfe
Re: Brake Pedal goes to floor sometimes?
I had that problem once. Ended up being a bad master cylinder.
Car: 85 Iroc-Z
Could something have possibly happened to the master cylinder when I bench bled it?
Received 1,862 Likes
Or, as cheeeep as those are, just change it out and be done with it.
Life is already too short; no sense making it even shorter over a defective $15 master cyl.
1 Post
Car: 1985 Camaro Iroc-Z
Engine: 350 5.7 TPI
mine just started doing that today...I was slowing pulling out of my apartment complex & noticed my brake pedal went all the way to the floor & didnt stop so I let off & pressed on my brakes again & it stopped. As I drive down the street if I pump my brakes it stops great.
I've heard when bleeding the master you push the seals further than they normally go and they can hit deposits/dirt that have been left behind after years of use, and It will ruin the seals causing the issues we are experiencing. Like sofakingdom said, masters are cheaper than a wreck/injury, they are old anyway so replacing them is not a bad idea anyways. If either of you do replace the master and it fixes the issue, please post up!
1 Post
Engine: 350 5.7 TPI
I don't have any leaks & I'm sure it isn't my brake booster so I will definitely be changing my master cylinder tomorrow after work. Good thing my Iroc isn't my DD.
1 Post
Engine: 350 5.7 TPI
so it was the master cylinder! changed it out & now my Iroc is braking great! Just a quick tip: BENCH BLEED, BENCH BLEED, BENCH BLEED! Makes installation way easier...
1992 Trans Am
05-10-2023 07:19 PM
Night rider327
09-02-2015 04:17 AM
