SSBC Quick Change and Brake hoses
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Anyone else using SSBC's quick change calipers? If so, what hoses did you use?
When I got mine I could not find the Earls that were made up as an OEM replacement so I ordered Russel. Those would hit the brake line bracket where the flex hose meets the steel line because the fitting angled outward.
I put the stock hoses back on and noticed the other day while doing a starter that at least one side is also hitting the bracket.
My car is also lowered with Eibach springs.
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Re: SSBC Quick Change and Brake hoses
I find it hard to believe that I can be the only one here with these calipers. I did search before posting and had seen where some others stated they were going to install them.
Did I ask a question that was too hard???
Car: 87' IROC
I am not aware of many people using those calipers. In any case how about a picture so the rest of us know what you are talking about?
Car: 89 Trans Am GTA
Engine: 5.7 350 TPI L98
Axle/Gears: Borg-Warner 3.27
You won't be the only one for long, got my SSBC kit today just gotta wait till it warms up around here.
1992 Trans Am
05-10-2023 07:19 PM
