LS1 rear disc dust shield
Car: 89 Iroc Z28
Engine: Crate ZZ3 Carb.
Transmission: 700R4 w/2800 TSI 12"
Axle/Gears: 10 bolt 26 373 series2 Auburn
I'm currently in the middle of a 10 bolt drum/disc swap and could use some help locating replacement dust shields for the LS1 12" rear disc. The disc are from a 98 base so if there any conflicting info please force me to clarify or better yet correct me if I'm wrong. Thanks in advance
Car: 89 Iroc Z28
Re: LS1 rear disc dust shield
Is there any input regarding running with out?
RBob, thanks for the info.
JamesC
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
On LS1s, you need that shield as mentioned above.
Ed
Ed
Car: 89 Iroc Z28
Gentlemen, thank you very much for your input it's priceless. Just as a FYI the Brake shield GM part#'s L side# 12454976 and R side# 1245977 and can be found here.
http://www.rmsautoparts.com/index.php
Thanks again for all your help.
hectre13
12-11-2023 08:14 AM
Eric-86sc
04-03-2016 03:52 PM
sailtexas186548
01-19-2016 12:21 PM
Genopsyde
11-11-2015 10:46 PM
