Rear Brake Question 9 bolt brakes on 4th gen rear?
1 Post
Car: 1989 IROC-Z28 Camaro
Engine: 403 LSX
Transmission: TH400
Axle/Gears: Moser 9" 3.25's
I have an 89' IROCZ with a BW 9 bolt rear end that has disc brakes. I picked up a 10 bolt from a 02' SS Camaro that I want to swap in, but it came without any brake components. So my question is, will my stock 89' 9 bolt 3rd Gen brakes, bolt up to the 02' SS 10 bolt housing? I know that I may need to get longer hard lines because the 10 bolt is longer than the 9 bolt. That is easy though. Has anyone done this or knows if it will work, or anything I need to do? Thank you.
-Sean
-Sean
Re: Rear Brake Question 9 bolt brakes on 4th gen rear?
http://www.flynbye.com/catalog/c1_p5.html
Also the following FAQ may provide some food for thought (parking brake, speedo gears, etc.):
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
1 Post
Engine: 403 LSX
Transmission: TH400
The 9-bolt back plate won't fit the 10-bolt; however, with the correct backing plate, all should be good to go. The 10-bolt plates can be purchased from the site below:
JamesC
JamesC
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
hectre13
12-11-2023 08:14 AM
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
