Locked up front caliper while driving?
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Last year what I think were original calipers needed a pad change. When I did this they were very difficult to push back with a c clamp. After a test drive the front passenger side was so locked up it nearly caught fire. So I went to the parts store and bought a new one for both sides. Now that was last summer, even with the new calipers the car still pulls to the side. So today while out driving the front passenger side locked up and started smoking like hell and I got my girlfriend to pick me up another caliper and changed it on the side of the road. This one does not lock up but the uneven braking is still there. It still pulls to the side. Could it be the flex lines? They look iffy most likely stock. Everything else is new which is kinda scary because the last time it was practically on fire. Any ideas?
Re: Locked up front caliper while driving?
JamesC
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Guide pins are new yes. I will order new flex lines. Thanks for the replies!
Car: 1986 Camaro
Engine: 436" SBC
Transmission: TH350, 8" Converter
Axle/Gears: S60 with 4:11 and Locker
I had this problem doing 130 down the track. I replaced all the rubber lines with braided russells, problem solved.
Car: 1991 Camaro Z/28 Convertible
Engine: LB9 305
Transmission: A4
Axle/Gears: Stock
Source for the braided lines? or any other recommendations for the replacement of the lines?
Car: 1986 Camaro
Engine: 436" SBC
Russell makes them as a stock replacement.
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Ok did the lines swap and the problem is solved. Picked up flex lines from Rockauto (kick *** prices). Rock auto was about $20 cheaper per line then anything local.
Car: 1985 T/A
Engine: LG4
Transmission: 200r4
Axle/Gears: Stock
I know this is an old thread, but better than making a new one, as I have mostly the same problem.
I have an 85, it's in really rough shape but it drives.
The rear drivers' side (4w disc) brake is dragging, and about two days after i bought the car, the front drivers' wheel let out a loud squeal and there was a lot of resistance from that wheel. I parked it about 2 blocks after the noise, and actually burned my fingers on the rim. I'm assuming the caliper locked up, there's no grinding so i don't think it's a bearing. I'm new to F-bodies and RWD cars in general, i've driven saturns for the last 3 years.
All that being said, do you think any auto parts chain stores will carry the braided lines? We have an o'reilly's, a napa, and a car quest in my town.
What else should i check on that wheel if it does turn out to be the caliper locking and not the bearing?
Thanks for all the help.
Miles.
Miles.
Car: 1985 T/A
Engine: LG4
Transmission: 200r4
Axle/Gears: Stock
1 Post
Car: 92 RS camaro, 99 Z-24 cavalier
Engine: 5.0L TBI, 2.4L
Ok im having a similar problem as the original poster. I changed the pads on the front and one of the calipers was really hard to press back in on the passenger side front. After I finally got it to press in I had a hard time to even get the caliper back on the rotor. I no I will need new brake hoses because my current ones are looking pretty bad. When I test drove the vehicle while braking it pulled to the left but at times while accelerating it pulled to the right. When I called autozone for a price check on the lines they said they carried 2 for an RS camaro. One for the performance package and one without the package. How do I tell which package my car has for sure before I start buying parts? The car is a 1992 305 automatic RS camaro.
1 Post
Ok thanks. Out of curiousity which cars come with the 1LE setup?
1992 Trans Am
05-10-2023 07:19 PM
1992rs/ss
05-19-2020 07:02 PM
