Where's my Brake Fluid!?
I was out and about and the pedal got real spongy. I had a look at the MC and it was empty. Both Chambers had but a puddle in it. Theres nothing at the calipers and the lnes appear to be in good shape. My question is can this fluid get inside the booster? If so can i get it out of the booster? Worse than that, what happens if the engine consumes this brake fluid?
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: Where's my Brake Fluid!?
The back of the master can leak and the fluid will go into the booster. If that happens, I would sugest replacing the booster as the brake fluid can eat at the rubber in the booster.
When was the last time you checked the fluid level and are your brake pads low?
My front pads are quite low and the rear are just like new seeing as they dont do a thing. I understand low pads would account for some fluid loss but this is empty, both reservoirs. There is no evidence of a leak at the back of the MC and the vacuum port and hose appear to be dry.
I would unbolt the master from the booster and check. Its only two nuts so it only takes a minute. Then you will know for sure.
dbrochard
10-03-2015 12:43 PM
