4 channel 10 bolt work on 3rd gen without ABS?
Engine: Cammed 6.0L LSX
I've got a 4th gen rear in my car but its a 3 channel (non-ABS), and I found another one for my dads IROC-Z that is a 4 channel rear. Will it work without an ABS equipped vehicle? I'm wondering if the rear will have a small hole for a sensor that will simply need to be covered, or will it flat out not even work?
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: 4 channel 10 bolt work on 3rd gen without ABS?
The axles are the same. Wether it has an ABS sensor or not doesnt matter if your car does not have ABS. Just leave the sensor in to plug the hole.
Terrell351
06-13-2021 01:13 PM
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
