Wilwood D52 Calipers, srtaight replancement?
Car: 1990 Iroc-Z28
Engine: 350HSR
Transmission: HD 700r4 B&M Stage2 SK
So im looking at these Wilwood D52 Calipers
http://www.wilwood.com/CaliperList.a...0Dual%20Piston
and im just checking, 1990 Camaro iroc, used D52 pads/calipers stock right?
im hoping to just do a direct replacement, with some D/S rotors , stainless lines ect
but i guess these are a few pounds lighter and have a lil over double the orginal stoping power
thoughts?
thoughts?
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: Wilwood D52 Calipers, srtaight replancement?
you wont have double the stopping power, the pistons are smaller. You will see an improvement over the old stock parts, but its not going to be earthshattering.
what do those cost anyway?
Car: 1990 Iroc-Z28
Engine: 350HSR
there not overly expensive at all, i was originally going to get there front brake kit but im going with these guys now,
Car: check
Engine: check
Transmission: check
thoughts?
thoughts?
The D52 is a popular caliper. GM used it on many vehicles. IIRC it was first used in the late '60s.
RBob.
Car: check
Engine: check
Transmission: check
RBob.
Car: 1990 Iroc-Z28
Engine: 350HSR
so they wont fit my car though?
Car: 1990 Iroc-Z28
Engine: 350HSR
how much of a difference in there between front and rear calipers?
does anyone make a rear kit?
Car: check
Engine: check
Transmission: check
Which front and rear calipers? Stock, LS1, 1LE, D52's. 99.9% of this info is on the 'net.
Many kits are available for rear disc set ups. Best bet is to grab a set from an LS1 f-body and bolt them on.
RBob.
RBob.
Car: 1990 Iroc-Z28
Engine: 350HSR
the stock ones, i took a poke around on here but didnt find much
Car: check
Engine: check
Transmission: check
There is a lot of difference between the front and rear calipers. The biggest being the rear caliper has a parking brake mechanism. The second being the piston area.
Then there are two different front calipers used in 3rd gens, along with 2 different rear calipers used in 3rd gens.
Fronts:
1) a cast iron single piston floating caliper was used (stock brakes)
2) an aluminum dual piston guided pad caliper was used (PBR, 1LE brakes)
Rears:
1) a cast iron single piston caliper was used
2) an aluminum single piston caliper was used (PBR)
RBob.
Fronts:
Rears:
RBob.
Car: 1990 Iroc-Z28
Engine: 350HSR
do you know of any aftermarket rear kits that arent uber expensive? ive been poking around and am only find ls1/corvette kits for 900-1500 bucks.
Car: '92 Camaro RS
Engine: 454 Multi-port EFI Big Block
Transmission: T5-anyone have a T56 for sale?
Thirdgen camaros with the standard 10.5 inch rotors
used the metric D154 calipers.
Wilwood and other companys offer this caliper with a larger
piston than stock but no dual pistons calipers are available to
my knowledge.
my knowledge.
Car: 1990 Iroc-Z28
Engine: 350HSR
ive been looking around on willwood/SSBC and a few others and have found nothing
Car: 1990 Iroc-Z28
Engine: 350HSR
Car: '92 Camaro RS
The caliper at the top of that page is the D52.
The 2 models of calipers below that are the D154
or whats called the GM metric calipers. They will
bolt on to our cars.
The D52 and D154 designation is actually the
generic part number for the brake pads.
You can also find similar calipers made by Howe
and US Brake. Look at the circle track racing stuff.
Alot of racing classes require these guys to run
OE brakes but if you're not cheat'n you're not racing.
Car: '92 Camaro RS
Sorry, I stand corrected. It has been brought
to my attention that stock replacement dual
piston calipers are available for thirdgens as
a bolt on.
Check out SSBC part number A181 or Summit
racing has their own under part# SUM-BK181.
Price is a little high but if you don't want to
cut up your spindles and just want something
a bit better than stock, this is a good alternative.
a bolt on.
Car: 1990 Iroc-Z28
Engine: 350HSR
a bolt on.
a bolt on.
yes i have looked at those, im just concerned with finding a rear set up, owuld have to have the E-brake and everything.
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
a bolt on.
a bolt on.
Car: check
Engine: check
Transmission: check
Which means for the same clamping force 42% more foot pressure on the pedal is required. So instead of 100 pounds of foot/leg on the pedal, 142 pounds of foot/leg are required.
With an aggressive enough pad material this can be made up for. But at the cost of a faster wearing rotor and a more expensive brake pad.
RBob.
Car: '92 Camaro RS
Be careful before going with these calipers. They have a lot less piston area then the stock calipers. 3.5 sq-in vs. 5.0 sq-in for the stock ones.
RBob.
RBob.
Very good point RBob,
I never looked at the total area of those pistons,
Who needs 2 little ones when you can have 1 big one.
So the large diameter OE caliper is the way to go in this application.
Stock=2.38" diameter or 4.45sq-in.
large (Wilwood and other companys)=2.75" diameter or 5.94sq-in.
Thats a 25% increase in clamping force using your example.
$340 for a 42% decrease in braking performance. Sounds like a
great deal to me.
SSBC should maybe hire a new engineer,
or how bout a new marketing team to tell us why those 2 little
pistons are so much better.
Car: check
Engine: check
Transmission: check
great deal to me.
great deal to me.
The piston diameter at the seal is 2.52" for the stock 3rd gen metric caliper. So it is a 5 sq-in piston area. Pull back the dust boot and check it out.
As for single vs dual pistons, generally speaking, the more pistons the better the "feel." This is the feedback the driver gets from the brakes. The greater number of pistons spreads the load over a greater area of the pad.
This means less pad deflection and a better sweet spot.
SSBC should maybe hire a new engineer, or how bout a new marketing team
RBob.
Car: 1990 Iroc-Z28
Engine: 350HSR
and yea why would they even bother producing these smaller ones? i get the dual piston spreading the clamping force more evenly but is seems like a bit of a waste for not much gain.
im probably just going to get some new OEM rear calipers and get willwoods front brake set up. should be sufficent for a DD and some racing id say. i just prefered a more balanceed system but cannot afford two 800-900 dollar kits
Car: check
Engine: check
Transmission: check
oh not at all, just picturing the difference in my head , seemed odd
That is a good question that I can only agree with. Several years ago I looked at them and came to the same conclusion. What are they thinking?
As for an upgrade, you don't necessarily need to buy a kit. Although I did some of the work myself I was able to piece together a front set up. It is the 4th gen Corvette standard duty parts ('86 - '96).
Purchased the rotors new (12" x .81", rear). The calipers and abutments from a salvage yard. These were actually in decent condition with fairly new PBR pads. Did the stock rotor to hub mods myself. And had the calipers brackets made locally.
Then did the spindle mods too. Best to remove them from the car for this. I did one on the car and decided to R&R the other side for an off the car mod.
Note that this was many years ago before these mods and pieces were available elsewhere.
But it doesn't mean that they still can't be done DIY.
The 12" C4 standard calipers have less piston area then the stock calipers. But the increased rotor diameter makes up for most of this. So in the end the pedal pressure is about 5% more for the same clamping force.
But the better feel and lower fade more then makes up for this. I've said it before, and I'll say it again, these are the brakes that should have been stock on our 3rd gens...
And behind 15" wheels, it is all rotor. So the looks are also there.
BobR.
Car: '92 Camaro RS
[quote=RBob;4509944]Yes & no. You mentioned 2.38" pistons on the stock caliper. This isn't true where it counts. The piston necks down to 2-3/8" where it meets the pad. But isn't what matters when it comes to clamping force.
Thats interesting, good to know when making a comparison.
The specs I wrote are well published by several manufactures
(Willwood, Howe, US Brake, etc.)
Never assume anything I guess.
And you are definetly correct, we have more choices than most
these days for brake upgades. LS1 and Corvette brakes can be
installed for very little money if do some research, shop around
and use some ingenuity.
Worth every bit of the effort
Car: 1990 Iroc-Z28
Engine: 350HSR
[quote=fastcars;4510121]
i did like the idea of the vette/ls1 replancement, but the supply of there parts is very limited around here, in fact ive never even found a V8 Camaro/firebird in the junkyard and no one seems to part out stuff round here.
i was really hoping for just a lil bit of a boost to my braking as per my slighlty abover average speeds lol
Car: 1990 Iroc-Z28
Engine: 350HSR
what would you guys say is the most cost effcient brake kit out there besides the vette/ls1?
and have either of you upgraded the rears? what did you use?
the_hamturdler
09-30-2015 12:50 PM
