Banjo Bolt size?
Car: 88' Iroc-z
Transmission: T-5 WC
Axle/Gears: 3.73 9-bolt
Banjo Bolt size?
Hey gang,
I just started installing my Goodridge s/s brake line kit and made a minor mistake on the install. I accidently had the front passenger brake line pointed in the wrong direction, so when I went back to reinstall the bolt with need crush washers, and it snapped. Luckily there was enough of the body so I could take it out by hand. Now the only thing is I need a new bolt but don't know what size. Also, does anyone kno the exact torque rating for these bolts? My manual says 18-30ft. lbs. The car is a 88' Iroc, without the 1LE package. Sound right? Thanks.
Re: Banjo Bolt size?
Do you know the torque for the 2 bolts holding the front single piston caliper on? I'm thinking that is all the torque specs I need to replace the front calipers.
Oh, and when you guys replace the calipers. Are you guys prefilling the caliper with brake fluid? It does seem like it will be messy. As while you pull the brake hose to swap it to the new caliper. Brake fluid will continually dump from the brake hose.
toronto formula
11-10-2015 06:17 AM
gixxer92
09-01-2015 04:32 PM
knight72
08-10-2015 09:32 PM
