brake line fittings
Car: 1984 Trans am
Engine: V8
brake line fittings
bought a aftermarket new combination valve for my 84 trans am only 1 problem the fittings on the lines dont fit on the new valve. does the whole line have to be changed or can i go to a mechaniac and will they just change the fittings?
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: brake line fittings
you can change the fittings or get adapters, if you can find them
1 Post
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
try searching google, and hit the shopping tab at the top after search. helps. adapters are the way to go but, i recommend the actual brake line with adapters installed. autozone has tons of these adapter brake line prefabed conversions you have to bend the lines. take in you proportion valve and physically yourself check the threading. Autozone with force it, but ask for complete access to the brake lines way in the back. good luck. mines this size off the master cylinder: flare nut size for the front brakes on the master is 12mm and coarse thread, the back brakes port is 14mm fine thread.
Chances are your new combo valve has sae threads for an inverted 45degree flare where your oem one has a metric bubble flare and as such metric lines and not 3/16 lines. You can not mix the 2, it's either adapters or a different combination valve
It's possible that an OE 84 has SAE threads. Not only does the 82-83/84 valve look a bit different from later valves but the line attachments are different as well. The older valve can be seen several times in the following link:
https://www.thirdgen.org/forums/brak...ing-valve.html
JamesC
JamesC
Car: 1988 Camaro, 1986 S10, 2000 Harley
Engine: LS6
Axle/Gears: 3.75 9" ford trac loc
Most aftermarket valves that I have saw have 1/8" female pipe threads. This makes them fairly universal. You use an adapter with 1/8"male pipe to whatever your lines require. Dean
