brake lever spring help please
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
ok so I tried replacing the shoes today. I have rear drum brakes. I went to start dissasembling. I got the parking brake lever off of the spring (it took a lot of force?). when i got the new shoes ready to put on I couldn't get the lever to attach to the parking brake spring. I made sure the emergency brake was off. I even put the emergency brake on then back off again. It's like the hook on the lever is to narrow to go on the spring. I have been going insane (like literally, laughing and all that). Is there some kind of trick to get the lever on the spring or to you just have to use ultra force to get it on? OH and also, do our cars have rear wheel bearings for drums? Thank you for your help.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Getting My Bearings
Re: Bearings.
Your car does not have rear wheel bearings per se, however it does have axel bearings.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog lights on in good weather beware. Low performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime, and the nitwits that need headlights for a little rain
Happy Racing!
