Tons of C4 HD questions
Car: Check The Sig
Ok, just picked up a C4 HD set up from a member of the local site.
He said he used the standard banjo bolts and brake hoses, but I tried to reuse mine, and its not going in nearly as smooth as stock?
Where can I get banjo bolts for these calipers? I think I might have crossthreaded the one thinking that all I needed was a little muscle to get it in there, but it went in cockeyed and Im pretty sure Im gunna end up buying a new caliper..yay for me
Also, brake hoses? they look like they will work, but the thick black plastic hose covering plays with the hose fitting close to the caliper.
Also, I was looking at the brake swap and wheel fitment sticky, and am looking to put on a set of ZR1 wheels, 17x9's up front. they are 4th gen offset. It listed 2 C4 HD's, one using the 1LE bearings and the other using the stockers...how would I be able to tell the difference? Just looking at it, the rotor seems to be much farther away from the strut/spindle then the stocker 10 inch rotor was. I know Ill need spacers, but I dont want to order 2 inch spacers and then have the front wheels sticking out?
Car: Check The Sig
Re: Tons of C4 HD questions
Ok, orderd 2 banjo or brake hose fitting bolts for the calipers.
Looks like I have that solved..hopefully.
I still have questions on the hoses if they will work. I really hope that teh caliper is salvageable...I dont feel like picking up a new caliper.
1 Post
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
I am working on getting my webpage back up which has been down for over a year.. this should answer all your questions, look under car --> brake upgrade
http://lukeskaff.com/
enjoy
enjoy
Car: Check The Sig
Thank you, but there is no answer for brake hoses. Can I reuse my stock brake hoses?
And still no answer as to how can I find out what kind of offset I now have. I need to know this so I can order the correct spacers.
1 Post
Car: 1989 Iroc-Z
The brake hose question is answered in the FAQ section of the site. You can use your factory brake hoses. I do not know about the new total offset.
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
You may need to slightly trim the hose covering to get them to sit flush against the caliper but they should work.
As for spacing, the HDs push out a bit further than the regular kits do (.6" added vice .3") so I'd only run a 1.25"-1.4" spacer as opposed to the 1.75"-2" spacer that a kit like this usually needs.
Ed
