brake caliper bolt hole stripped
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
when i took the front caliper off ,i noticed the bottom bolt was really loose now i know why it was stripped from the guy b4 .they had thread tape on it , and i can see they drilled a hole at the end to put a cotter key in it will this work or not? the cotter key is so it can't come out.the top one is fine.
Guest
Posts: n/a
Re: brake caliper bolt hole stripped
Not really. The caliper slides on that bolt, or at least its supposed to, and the cotter pin would continually end up further away from the caliper as the pads wear so the bolt would be able to move around a lot more as the pads wore down. It cant really fall out but its just going to get worse and could cause the bolt to break eventually. Not a good thing. I'd look at a helicoil for the spindle, or replace the spindle.
evilstuie
01-09-2020 08:29 PM
84z96L31vortec
08-20-2017 12:16 AM
Eric-86sc
04-03-2016 03:52 PM
84z96L31vortec
08-10-2015 08:27 PM
