Switching to 9 Bolt: Brake Q's
Car: Check The Sig
I have a 9 bolt im putting in to replace my busted 10 bolt. Im also going from drums to disks. Which rear brake parts am I looking for? I keep seeing a reference to with performance brakes or without. Im not sure if the 9 bolt disk rear came with only 1LE's, or could they come on standard cars? Which pads and rotors am I looking for?
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Switching to 9 Bolt: Brake Q's
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
Car: Check The Sig
Ah, thank you for clearing that up.
Another question. Who the hell sells good brake rotors and pads for these calipers? Id like to get a set of Hawk HPS pads if possible, but I have only seen them for "non-performance package" rear brakes.
I have used Performance Friction z-rated pads for the 9-bolt brakes.
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
Your lucky you have the PBR setup. I've had two 9 bolts with the older '88 disc brakes and the calipers are junk. And 3 were messed up. 2 were frozen, one worked and one leaked all over.
1992 Trans Am
05-10-2023 07:19 PM
Street Lethal
04-30-2019 12:14 PM
