LS1 brakes on a 9 bolt question
Car: 91Z28
Transmission: WC T-5
Axle/Gears: 10 Bolt Posi, 3.08
Ok, so I have my LS1 plates redrilled to fit the holes on the axle. Everything lines up beautifully. My only question is about the spacer that folks have made. I have no access to a machine shop so I cant get all trick like some. I did notice that the space I need to shim is the exaxt size of the axle seal. Can I simply put a second seal behind the first to shim this? Please let me know, thanks!
Bill
Bill
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: LS1 brakes on a 9 bolt question
Well, the thickness you need is the difference between the 9 bolt plate and the LS1 plate.
If indeed the seal is that thickness, then yes.
How would you put it on? Press the bearing off and add two seals?
Car: 91Z28
Actually I took a new seal and filled it with JB weld. Once it hardens i will cut it like yours.
Sounds feasable, make sure it is the right thickness.
Car: Camaro
Engine: 6.2L
I made mine with a couple of hole saws. The extra sheet metal shim isnt needed one 1/4" spacer will work fine. Check out this thread and note I linked in one of my posts to another thread so check that out too and you should be fine
https://www.thirdgen.org/forums/brak...discs-9-a.html
hectre13
12-11-2023 08:14 AM
84z96L31vortec
08-20-2017 12:16 AM
1992 Trans Am
08-08-2015 08:16 PM
