Another 4th Gen Parking Brake Question
1 Post
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 10 bolt Richmond 3.73 posi w/ discs
I've searched throughout but can't find an answer to my problem. I swapped in a 4th gen axle this weekend into my 91 RS. The brakes came off a 94 Trans Am. After doing research on here I read that you could get the parking brake cables from a 90-92 Camaro that would work without modifications. I got the long ones (1460mm) but they are too long. The extra length is where the cable mounts to the caliper and hooks to the parking brake lever. There is about 3-4" of excess cable. Of all the pictures I've seen on here of 4th gen calipers, none look like mine. Mine have PBR on the caliper but have there is a 2-3" diameter round disc that is probably 0.5" -1" thick that hangs towards the center of the car (sorry I don't have a picture at the moment). Can any one help me out?
Re: Another 4th Gen Parking Brake Question
I swapped in a 4th gen axle this weekend into my 91 RS. The brakes came off a 94 Trans Am. After doing research on here I read that you could get the parking brake cables from a 90-92 Camaro that would work without modifications. I got the long ones (1460mm) but they are too long. Of all the pictures I've seen on here of 4th gen calipers, none look like mine. Mine have PBR on the caliper but have there is a 2-3" diameter round disc that is probably 0.5" -1" thick that hangs towards the center of the car Can any one help me out?
JamesC
1 Post
Car: 1991 Camaro RS
Engine: 355
The part in question is a vibration dampener. No experience with fourthgen rears; however, the LTI PBR's, with the exception the dampener, are similar to 89-92 PBR's which I'm running in my thirdgen 10-bolt. I'm using e-brake cables from CarQuest (P/N BRK 8788, 1st design, 1434 mm).
JamesC
JamesC
I purchased the 2nd design because thats what I read from multiple threads on here.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
see my post here for what I did on my 4th gen rear swap:
https://www.thirdgen.org/forums/brak...s-finding.html
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
