86 9 bolt 'Aussie' rear backing plate question
Old 10-17-2007 | 10:17 PM
dcrace58's Avatar
I bought a 9 bolt rear out of an 86 Camaro from a salvage yard and it turns out to be the rear built in Australia. Will be using it in a street rod. I disassembled the rear, cleaned, sandblasted, removed all the brackets, painted and reassembled with new axle bearigs and seals. When I got to installing the axles with the backing plate / caliper mount it seems as though both the mounting plates are identical, and when I mount them, the only way they seem to mount is with one caliper facing rearward and one caliper facing to the front. This is driving me crazy! Am I nuts or is this the way they were? Sorry I didn't pay more attention when I took them apart!!
Please help!!
Old 10-18-2007 | 12:54 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Re: 86 9 bolt 'Aussie' rear backing plate question
That's correct for an '86, one leading caliper, one trailing. GM saved some cash by using the same caliper and plate on both sides.
Ed
Old 10-18-2007 | 09:37 AM
dcrace58's Avatar
Thanks for the info Ed. Do you happen to know which side forward and which side rear or doesn't it matter...maybe for an e-brake set up??
Dave
Old 10-20-2007 | 07:48 PM
ebmiller88's Avatar
This is how the calipers were installed on my 1988 so yours should be the same, driver's side trailing, passenger side leading:
Old 10-23-2007 | 07:17 PM
It's not hard to figure out; just remember, the bleeder screws go at the top of the caliper. Once you establish that, there's only one way for them to go.
Frozer!!!
01-19-2024 05:55 PM
MoJoe
Fabrication
08-19-2017 08:12 PM
sailtexas186548
01-19-2016 01:21 PM
sailtexas186548
Brakes
08-13-2015 12:47 PM
1992 Trans Am
08-08-2015 09:16 PM
