Hydroboost for 3rd Gen
1 Post
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
I'm thinking about converting to a hydtoboost system. I see a kit on Summit Racing for our car. the price is a little stiff but I'm serious looking to do an update to the Camaro. I want to buy the PBS system w/Wilwood Master Cylinder. Any have any experience with these kits?
http://store.summitracing.com/partde...D753CH&FROM=MG
http://store.summitracing.com/partde...D8555P&FROM=MG
Car: 87 trans am
Axle/Gears: 3.42 SLP rear
Re: Hydroboost for 3rd Gen
We have hydroboost on our 78 cutlass. I'm not found of it, of course it might be ok if the car ran better.
1 Post
Car: 83 Trans Am
Engine: LT1 350
Transmission: 5 Speed manual
Axle/Gears: 3.73 10bolt till it breaks
Hydroboost is great if you get a radical cam that produces low vacuum, but if its a stocker or mildly modified engine then I think you would be wasting your money. I personally wouldnt go through all the trouble just to have hydroboost. Although I do think they look really cool.
1 Post
1 Post
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Strip it from a full size truck in the junkyard.
Little bit of laying would get u a great setup easily, without spending the money I see the kits go for.
People have swapped them into a few F's and tons of G bodies.
later
Jeremy
later
Jeremy
1 Post
Do they have hydroboost that's direct bolt-in or would I need major modication with the rod? What vechiles is comparable with the 3rd gen that would fit. I dont mind taking a dremel to open up the holes, but what about the rod being long enough or too short.
1 Post
Car: 83 Trans Am
Engine: LT1 350
You can buy adjustable rods. I'm not sure where but I know you can because sometimes when replacing boosters or master cylinders on some of the newer cars, the rods arent adjustable and you have to use an adjustable type to complete the repair. I'd figure out the approximate length you need and a dealer would probably be able to match one up for ya.
built, custom, driveshaft, engineering, form, hydroboost, nc, order, pbs, pro, racing, strange, summit, transmissions, wilmington
