brake recall kit...id this part please
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Transmission: stage2 700r4
Axle/Gears: 2.73 for now
Im laying out the parts to do my rear disc brake rec all. The problem Im having is that I dont know where this part goes. I didnt pull anythng off the old one that looks like this: therefore, i dont know where it goes. There are (2) of them in the kit, one for each side im assuming.
Car: 89 formula, 89 Cadillac Brougham
Engine: 355,HSR,patriot alum. heads,TFS cam
Transmission: 700r4, 2500 B&M stall, shift kit
Axle/Gears: 3.73 ten bolt, powertrax locker
Re: brake recall kit...id this part please
i want to say it locates the pad to the piston
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
^ partially, i think its some sort of anti rattle clip
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
alight cool...ill check if it clips onto the piston some how.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Line up the tabs on the inside of the ring with the corresponding gaps in the face of the piston, and twist so that the tabs become trapped in the groove around the end of the piston, then squeeze the pad into the clips.
Street Lethal
08-12-2015 11:33 AM
