Rear caliper recall kit worked great 4 years ago but!!!
Car: 1984 TA, 2001 Monte Carlo SS
Engine: 305 LG4, 3.8 200 HP
OK I did the recall kit rebuild about 4 years ago and now i need new pads (by the way the kit worked great never a problem since i did it) but I don't know how to push the piston back in the caliper so the new pads will fit on the rotors i don't want to tear one apart to see what is stopping it and i don't remember whats inside it since its been so long ago. so can anyone please help me with this. I really need this back on the road asap and need to get my 01 Monte Carlo in the garage to some work on it too. It never ends always something to work on.LOL
Their is no other site like this on on the net I really love it. It has saved me so much time and money.
Kevin
Kevin
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Rear caliper recall kit worked great 4 years ago but!!!
Screw the piston into the caliper to retract it.
Thanks so much for a quick reply on that. I did try that but only by hand I didnt want to force it but now i will try with a little more force. Thanks again.
I turned the piston and one way it started out and the other way it did nothing do i need to something else before i do this?
Engine: 383 Carb
Transmission: 4L60
You have to apply pressure to it as your turn it back in.
I tried that but will try again thanks. I put a c-clamp on it and put pressure on it as i did but didn't keep pressure on it. I will let you know if i get it to work.... Thanks again.
Kevin
Kevin
Ok just wanted to let everyone know that it worked in case someone else had this problem. I put the c-clamp on it and put pressure one it and turned the piston in, I had to turn the c-clamp every time i did this. I tried to do this by hand but it wasn't enough pressure to make it go in. I have one side done and going out to get the other side done now. Thanks Apeiron for you help
Engine: 383 Carb
Transmission: 4L60
There's a tool made that presses and screws the piston at the same time.
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Transmission: stage2 700r4
Axle/Gears: 2.73 for now
Just for reference....is the correct 'recall kit" for our cars part number 18019028 from GM parts direct??
Also what do u mean by screwing it in??....I understand how to apply pressure with the c clamp, but i dont see where you screw something in or out to get the piston out.
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
That's the right PN for the kit.
The piston moves like a screw. turn the piston as you apply the c clamp pressure.
Car: 91 Camaro RS
Engine: 305 tbi
wish this was here when i did mine i had to just figure it out after i bent a big *** c clamp
Fast355
12-02-2016 06:33 PM
