Brake line adapter help
Car: '87 Formula
Engine: Ramjet 350
Can anyone tell me what fitting I need to adapt to the rear flex hose. We coudln't seem to find the right fitting at CarQuest. It takes a bubble flare, but don't know the size and thread. I'm trying to convert to 1/4" double flare so I can run a new line.
Thanks,
Ben
Thanks,
Ben
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I'm pretty sure it's a M10 x 1.25 as listed here for a 1/4" line:
http://www.fmsiinc.com/brake-line-fittings.htm
Ed
Ed
Car: '87 Formula
Engine: Ramjet 350
Thanks, crossing that over to Edelman (http://www.plews-edelmann.com/brochu...cation_id=2803) which CarQuest carries, looks like it should be part number 271330, for future reference to anyone looking for this.
Car: '87 Formula
Engine: Ramjet 350
Alright, I tried fitting the adapters that I had used on the front (3/16" ITN - M10x1.0) and its way too small for the back so it has to be M12 or something. Does anyone know for sure?
Car: '87 Formula
Engine: Ramjet 350
Re: Brake line adapter help
I don't remember, let me see if I can look up the receipt or pn for ya, I'll try and post a little later.
Any luck with finding the numbers? I am thinking 12 by 1.0...The Chevy dealership today said it was a 6mm line. Looking at the bottom of the page linked above, there is 12x1.0 and 12x1.5...
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
Hey JDud,
I've seen your posts asking about this, but I haven't made the time to go check it out. I have a LS1 master cylinder, and the front fitting (for the rear brakes) is definitely a M12 x 1.0. The rear fitting (for the front brakes) has a 1.5 thread pitch, but it's too big to be a 10mm and too small to be a 12mm. From looking at the FMSI parts page, it looks identical to a 11mm x 1.5 tube nut.
