play between wheel studs and wilwood rotors
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
why is there so much play between the holes in the wilwood rotor hubs and the axle studs? when i drive i constantly here the tapping of this over bumps and such
Received 1,839 Likes
here the tapping
Car: 1986 Camaro SC
yes the lug nuts are tight, but if i jack the car up with the e-brake on i can move the wheel a tad bit forward and back the axle hub moves within the rotor, i just did some research, this brake kit was already on the 12 bolt i bought, and it seems they have .52" stud holes and the rear has 12mm stock studs.
It could be that you are hearing the brake pads moving in the caliper.
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
Rotor should self center on the end of axle. Hub centric.
If the mounting surfaces are square and the bolts are tight there can be no movement.
Make sure that you have the right lug nuts. If they are the wrong taper where they meet the wheel, it will cause what you mentioned. Also make sure that the lug nuts are not touching the rotor. They couls be too long.
I vote for wrong lug nuts.
Car: 1986 Camaro SC
i did not get the rotors back from my uncle yet, the lug nuts are fine, the wheel doesnt move on the axle, the axle moves within the rotor stud holes. when i get the rotors back i'll check it out.
ambainb
04-25-2016 09:21 PM
