how hard is it to do wheel cylinder?
1 Post
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
well i found my problem both my wheel cylinders are shot...... anybody be able to give me ideas or steps how to do it im not a brake person.. its an 84 camaro rear brakes... thank you
Received 1,839 Likes
First, remove all the usual brake stuff, the shoes and all that, like you were doing a normal brake job. Then rotate all hardware on the wheel cyl (2 bolts, one line) counterclockwise. Allow gravity to take over. Hold new wheel cyl where the old one was. Rotate all hardware clockwise until tight. Re-install shoes and stuff. Bleed.
