rotors chewed up
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
rotors chewed up
Got an inspection and they told me my rotors were bad. So I took them off today in hopes I could get them refinished. Turns out theyre more messed up than I thought. I was just wondering what caused this. there are a lot of divits only on the inside of both rotors. Just curious. Thanks
New rotors and pads on the way.
Car: 91 formula
Engine: 350 tuned port. bolt ons
Looks to me like those are heat marks. It may be caused by a cheap rotor or your brake pads. but that rotor was under a lot of heat.
Car: 1989 IROC
Axle/Gears: 3.42 Auburn
Looks like heat marks to me to. Mine had lines in them from the sqeakers on the pads diging in them from the previous owner. So i took the time to replace the rotors pads and clean up and regrease the bearings. Wasn't expensive at all.
Car: 91 Camaro
Would bad/old brake pads cause this? Like I said Im just curious, Im putting on new rotors, bearing, and pads. Just wondering how this would happen for future knowledge. Thanks
the_hamturdler
09-30-2015 12:50 PM
the_hamturdler
09-22-2015 02:59 AM
