Can I reuse the copper washers for calipers?
Car: Camaro RS '91
Engine: 305 TBI
Transmission: Auto w/ TransGo shift kit
I wanted to buy new ones from NAPA but the guys said it costes them $25 for a bag of 10 and they don't stock them.
Do you think I can reuse mine?
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
Usually new calipers come with the copper washers. $25/10 is extreme, might as well get new calipers ($13/each) with the washers!
The washers form to the surface on the caliper and bolt, stopping it from leaking, hopefully.
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
You can get them anywhere Motormite/Dorman/HELP products are sold....they are cheap....usually 3.50-4.00 for
a pair. I would replace them, they are a one-time product.
Car: 1990 firebird
Engine: 3.1 v6
like my instructor saids "if you are stuck in the dessert and there is no autoparts store and you have no choice but to reuse it, go for it". I reused mine when i did my calipers because it didnt come with them. No leaks
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Those things are only a few cents each, maybe .50 max...but I do recommend replacing them every time you take the hose off.
Ed
Ed
Car: Camaro RS '91
Engine: 305 TBI
I'll go to the dealer to see if they have them. Lo-tec, thanks for the part number.
My plan was to change them but I just didn't expect NAPA not to carry them.
Thanks.
D.
Thanks.
D.
Car: check
Engine: check
Transmission: check
The copper washers can be re-softened by heating to dull red and dropping them in cool water. Don't need a lot of heat for dull red, so no oxy/actylene torches please.
Just a plumbers propane or a stove top is enough heat.
Note that this does not work with the aluminum washers, just the copper.
RBob.
RBob.
the_hamturdler
09-30-2015 12:50 PM
WhteRbt
09-21-2015 09:48 AM
