Caliper Mounting Bolts
What is the correct hex socket/wrench size to undue the caliper mounting bolt for a 1986 Firebird TA stock oem caliper. I bought a 10mm hex socket but it does not fit, a little too big.
That's what I am saying, 3/8" is 10 mm. I tried an 8 mm, which was a little too small, so must be 9 mm. I used a ruler on the caliper bolt opening. Measures 9 mm not 3/8" or 10 mm. My 3/8" or 10 mm hex socket is a little too big.
Car: '91 TA vert
Engine: turboLSx
3/8" is close to 10mm but not the same thing. So if you wanted to try a 3/8" then you might be able to get the calipers off.
EDIT: Seemed like I said that kind of dck-ish. But I'm meaning to give a light-hearted spin to this. Doesn't seem to be working.
you are correct. I went to an auto parts store before your post and tried one of their 3/8" hex socket in one of their caliper bolts. fit perfectly. tried my 10mm, did not fit. The reason I got the 10mm in the first place is because on the brake board there is a post on how to redo you brakes and the fellow mentions getting a 10mm hex wrench for the caliper. Maybe one of the moderators should change it to 3/8" so people won't waste money on the wrong socket ie. metric . Anyway thanks for your help. now I can do my brakes.
ambainb
04-25-2016 09:21 PM
Eric-86sc
04-03-2016 03:52 PM
sailtexas186548
01-19-2016 12:21 PM
Genopsyde
11-11-2015 10:46 PM
