The Mechanic Said He'd Never Seen It Before...
Car: 1986 C4 Corvette
Engine: 350 TPI L98
Transmission: Doug Nash 4+3
Axle/Gears: 3.07
So we take my '89 T/A (resto project) to the shop today to get the front wheel bearings replaced (it'd been making an awful grinding noise for the last few hundred miles). The mechanic said he'd never seen anything like it in all his years. Amazing the front wheel didn't fall off eh?
You're not seeing things - that be one busted rotor.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Looks nasty, but couldn't really have fallen off with the spindle nut holding it at least.
Car: '87 GTA hardtop, '86 IROC hardtop
Engine: 385 DFI, 350 carb
Transmission: T-56, T-5
Axle/Gears: ls1 torsen 10-bolt, 9-bolt disc
where those factory rotors or where they replacement cheap-o rotors?
just curious
Luke
just curious
Luke
Engine: 350 TPI L98
Axle/Gears: 3.07
just curious
Luke
just curious
Luke
I believe they were replacements - the rotor itself was still in fair condition with little wear. I doubt very much they were OEM.
Car: 1989 Formula 350
Engine: Stealth Rammed 350
Axle/Gears: 3.45 9 bolt
wow i hope that not what my rotor looks like when i go to change my wheel bearing. its been making some strange noises too.
Engine: 350 TPI L98
Axle/Gears: 3.07
well thats crazy ive never heard of nor seen that one happen either
wonder what the deal was
bearing race not in right ?
greased ?
loose nut ?
hmm
very curious
greased ?
loose nut ?
hmm
very curious
Engine: 350 TPI L98
Axle/Gears: 3.07
greased ?
loose nut ?
hmm
very curious
greased ?
loose nut ?
hmm
very curious
Car: 85 iroc-z
Engine: blown 350
Axle/Gears: 4.10
I had a 76 formula 350 that did this. it would go threw weel bearings about avery 3-4000 mi. befor and after a new roter turned out it had a bent spindel aparently it had bean hit on that side befor I owend it.
sjorgens
10-01-2015 07:54 PM
