PBR Rear Disc Question
I'm gathering all the parts to do a LT1 rear disc conversion and the C-5 Corvette front discs on my 82 Z-28 and for the most part, so far so good, however, I am looking for parts and or numbers for the e-brake. I have the new backing plates for 10 bolt, new PBR cailpers, abutments, Hawk pads, and new lines and proportioning valve coming from Ed Miller, but am unsure about what the assembly and brackets for the e-brake assembly is. Will the parts from a 4th gen rear setup work or do I need the parts from the PBR 3rd gen? I can still get the cables locally but would like to know if you can buy the ebrake assemlies and brackets from GM yet. Any help would be greatly appreciated.
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
'93-97 parts will work but you'll need the first design cables for them to fit right. In any case, use a cable with the PN 94264, Napa carries them.
Ed
Ed
hectre13
12-11-2023 08:14 AM
Eric-86sc
04-03-2016 03:52 PM
