So has anyone ever put together symptoms of a bad prop valve?
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I am getting to many conflicting suggestions to my brake problem.
Might be a useful to other and sticky it.
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
A proportioning valve is used to limit the maximum pressure going to the rear brakes. If your prop-valve isn't working you will have excessive wear on the rear brakes and rear brake lock-up problems. If the valve is stuck closed you will have very little rear brake wear. If your car has drum brakes out back make sure the wheel cylinders are 100% (no leaks, moving freely) before tearing your combo-valve (it has 3 functions on our cars) out and replacing.
backtothe80s
09-05-2015 12:39 AM
astro, bad, brake, gears, prop, propeller, proportional, proportioning, propotional, signs, stuck, symptoms, symtoms, synptoms, valve
