rear brake noise "ticking"
Car: 91 Z28
Transmission: built 700R4
Reciently I have noticed that when I am stoping in my 91 Z that the rear driver side brake set up seems to be making a ticking noise. Does anyone know what might be causing the "ticking" sound? Sorry I am not being verry specific, but that is the best way I can describe it. thanks for any info.
Rear Discs?
Mine make a sound too, rhythmic and irritating, untill i turn up the radio....
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
I'd say next step is checking for a bent axle. My brakes made a noise every revolution when I had a bent rear axle. The rotor doesn't spin on a perfect axis if the axle flange is bent at all, and the rotor makes more contact at a certain point in rotation than other points.
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Make sure it's not something simple like some brake part making contact with the rim as the wheel spins?
