Willwood Pads
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
Willwood Pads
Is their a choice of different types of pads for willwood disk brakes and where do the majority of people get them? Summit...?
Car: Agood2.8,
Engine: V6rsr,
Transmission: Afrikingoodtime
My experience with Wilwood brake pads has been terrible for any kind of street use. They are very noisy. I would only use them for track use, they are embarassing at street temps and have a very bad low speed moan. I have tried T,Q and, E compounds and all are noisy.
I have gone to EBC Greens for my Wilwood calipers for street and light track use. They are working decent so far and it has been about 4-5 months now. Autoxed it once hard and still no pad buildup usually associated with EBC greens when they overheat so my rotor temps are in a good range for using them.
As a side note- I had nothing but problems running EBC green pads on my 10.5" system because they just got to hot and left excessive pad buildup in no time. This gives the brakes a warped feeling.
Car: 1971 Corvette
Engine: 6.0 LS1 L92 heads sheet metal etc.
Transmission: M21 4-speed
Axle/Gears: 3.36
I have Wilwood Q pads on my c4hd front setup and they have been fine on the street. No noise that I noticed. They definately stop better with a little heat in them, though.
Anyone know a good low temp pad? I drive like an old lady most of the time and my brakes never get that hot.
Car: Agood2.8,
Engine: V6rsr,
Kyle, These guys were quick on shipping. I notice right now though they are currently out of stock on my fronts
http://www.perfectbrakes.com/products.asp?cat=3512
Most Wilwood fitments
http://www.perfectbrakes.com/wilwood.asp
Vintageracer
09-24-2017 12:34 PM
the_hamturdler
09-22-2015 02:59 AM
