Differences in late and early model spindles?
1 Post
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
I am finishing up school and about to head home fore the summer and work on my C4HD brake upgrade. I was wondering if these are late or early model spindles.
Here's a picture of the spindle, I lightly sandblasted it over spring break.
Car: 92 RS Convertable
Engine: RAMJET 350
Transmission: G-FORCE T-5
those look just like the spindles on my '92 (well before I hacked em up) raised bosses and all.
oh and thanks for starting the LS1 thread it was very helpfull
Ryan
(PS I went to Chantilly HS)
Ryan
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
As long as they have raised bosses, I would say they are the "late" design. Honestly, there isn't a big issue with using either one. I tend to use the "early" style without the bosses on LS1 kits as they may give a bit more bracket clearance to the rotor face, but not always. I'm not the best explainer but I hope you understand. With C4s, either type will be fine.
Ed
Ed
1 Post
Car: 1989 Iroc-Z
thanks ed, I understand what you mean
Do you have a picture on hand of the early model spindles? Since both will work fine now I am just curious on what GM changed.
Awesome, Yea this is off topic but oh well, I went there in the morning's senior year for a networking academy class. Wish I took shop now so I could have used the lifts and stuff.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I can agree with that...I really think it just depends on which foundry did the castings as I've pulled both types from various year cars. I know there are two different types but as for the years, there may be many differences.
Ed
Ed
Car: 85 IROC
Engine: 355
Transmission: Tremec 5 speed
Like Ed and Apeiron said, I have seen both types on cars at the salvage yard.
The difference lies in the area where the raised bosses are. The early style do not have the raised bosses so it seems like the "arms" where the holes we use are located, are thicker. If the arms are thicker, there is no need to raise the thread bosses to put the mounting surface for the factory dust shield in the correct place. I think the "early" style are better because when you drill the dust shield holes for big bolts like we use on our adapter brackets most of the raised thread bosses are drilled away. This leaves only a small area left on the spindle for your bracket to seat on. I have the late style spindles for my latest project (stock calipers/C4 rotors). But I wish I could have found some good early style instead.
1992rs/ss
16
01-28-2016 09:58 PM
