Brake caliper that won't bleed?
1 Post
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
Replaced master cyl/ por. valve, some new lines for the back and proceeded to bleed the entire system. Every thing bleed fine except for the front right caliper. Only a trickle of fluid came out the bleeder screw and the pedal would not go to the floor like when bleeding the rears and driver side. Does this indicate a bad caliper? Lines are not pinched. This was on my 85 Z28.
Last year I replaced a caliper on the rear of my 87 GTA. The new caliper did the same thing. I returned it for another and that one was fine.
I've been messing with brakes for quite some time and never encountered this before. Now all of a sudden it's happened twice in one year. Is this common? Is is worth trying to fix/rebuild the front caliper or just replace it? Lines/hoses do not look bad anywhere in the circut.
1 Post
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
Re: Brake caliper that won't bleed?
1: Remove and inspect the bleeder screw very carefully. Corrosion can clog the tiny hole at the bottom of the bleeder screw. Even a new caliper can have problems. Sometimes a bleeder screw is manufactured wrong with an undersized or even missing inlet hole. ( Motormite made a bad batch some time ago....). Check to make sure that the bleeder passage in the caliper itself is not clogged or machined incorrectly.
2: Replace both front brake hoses. They can deteriorate and collapse on the inside while looking OK on the outside. Good insurance to replace all brake hoses BTW.
1 Post
Engine: SBC, LS-x
Re: Re: Brake caliper that won't bleed?
Originally posted by Chickenman35
New Calipers or old?
I just mentioned the 87 GTA new caliper from last year cause the same thing happened. That bleeder was clear too. I could see light thru it. The 2nd new caliper worked fine. I'm not dealing with that right now at all. It's ok.
I pressed my luck so far getting brake lines apart. The hoses are origional so I suppose they should be replaced. I can put the torch on the brake line to brake hose fitting if it decides to give me a problem since I can't damage anything that won't be replaced. I just don't want to have to double flare anymore lines!
1 Post
Engine: SBC, LS-x
Originally posted by RB83L69
Especially if more than one caliper has done this, when fed by the same line
1 Post
Engine: SBC, LS-x
Like, a new one and an old one
1992rs/ss
05-19-2020 07:02 PM
sailtexas186548
01-19-2016 12:21 PM
